Hi! Internet connection is needed to renew token, confirm subscription, and download motion codes. It is not required during viewing.
Ask me anything
âask me anythingâ
I actually like the design of the new hoodies. $95 is a lot for a sweatshirt, any chance of getting a discount code?
thanks
Hi Mark! We donât have discount codes for the new hoodies.
Guardians 3 motion code doesnât work for me. Anyone else had trouble with the GotG 3 code? Itâs recognised by the HEMC but the chair doesnât move. Been trying to watch the movie since the code was released. I cannot watch it without the motion code. I just canât!
Hey Mac!
I noticed your post about having trouble with the motion code for Guardians of the Galaxy 3.
Let me jump in and try to help you out with this.
First off, I want to assure you that we ran extensive tests on the Guardians of the Galaxy 3 motion code with all our equipment in the lab, and it worked flawlessly.
However, I understand how frustrating it can be when things donât go as expected.
Here are a couple of tips that might help you get the motion code working smoothly:
Keep your HEMC (Home Entertainment Motion Controller) connected to the internet at all times. This will make sure that the motion codes are readily available whenever you need them.
By leaving the HEMC online, we can also remotely connect to it and check for any possible issues, so itâs a good idea to have it connected whenever possible.
Double-check the haptic movements settings to make sure they are not muted.
Also, adjust the intensity of the movement and vibration settings to 0dB for the best experience.
I hope these suggestions make a difference, and you can fully enjoy watching Guardians of the Galaxy 3 with the motion code activated.
If youâre still facing problems or have any more questions, donât hesitate to reach out to the tech support team at support@d-box.com.
Weâre here to assist and get things running smoothly for you!
Hi Luka.
Thanks for looking at my issue. All other motion codes work with no problems. Months ago, Violent Night and The Sea Beast didnât work for several weeks then started working after a while. I was worried in case this particular code was corrupted or something.
Do you mean itâs best to leave the HEMC on all the time? I usually turn it on just when Iâm going to watch something.
Iâll contact Support as suggested.
Thanks
Mac
The Blu-ray disc of Suzume has already been released in Japan. Can the motion code be launched as soon as possible?
We are aiming to have it available for Decembre 2023.
